查看: 4082|回复: 2
DE2-70_SYSTEM_CD_V1.3 問題
发表于 2009-11-21 10:03:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一.
.address_to_the_ssram({oSRAM_A[17:0],sram_dummy_addr}), V1.3 仍然為持 A[17:0]
.address_to_the_ssram({oSRAM_A[18:0],sram_dummy_addr}), 聽說要修改 A[18:0]
二.
所有 IP 都是舊的 Compiler ,導致警告訊息一堆.
# TCL File Generated by Component Editor 7.2 on:
# Fri Oct 05 17:51:07 CST 2007
# DO NOT MODIFY
 楼主| 发表于 2009-11-25 22:36:21 | 只看该作者
友晶DE2-70_SYSTEM_CD_V1.3範例 Warning 還真多,奇怪為什麼都當做煤看到?
AUDIO_DAC.V
133        .rdempty(dacfifo_empty),   <===","
wire  fifo_clear;<=====增加
176  assign fifo_clear = reg_fifo_clear;
DM9000A_IF.V
21 avs_s1_export_ENET_CLK,   <===","
发表于 2009-12-25 14:39:36 | 只看该作者
哈哈 ~ 是不是因為Quartus compile都給過ㄚ
GMT+8, 2026-11-6 16:13 , Processed in 0.035810 second(s), 15 queries .
