查看: 20809|回复: 13
关于友晶TRDB_ADA子板卡的范例使用问题
发表于 2009-12-17 16:06:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
小弟入门不久,刚刚拿到了友晶的TRDB_ADA的子板卡,准备插在DE2_70母板上使用。为了熟悉一下TRDB_ADA的使用,我把TRDB_ADA附带光盘中的“DE2_70_ADA”的这个设计范例拷贝到我的计算机上,准备编译一下下载到板子里面跑跑看,但是一编译这个工程,QUARTUS II 9.0就报错:很多实例找不到,实在不知道怎么解决,我把报错的情况截图放在下面了,那位大侠可以帮我解释一下为什么啊?先行谢过了
 楼主| 发表于 2009-12-17 16:11:08 | 只看该作者
上面的图看不清楚,我把出错信息贴在这里:
Info: Elaborated megafunction instantiation "pll:pll_100|altpll:altpll_component"
Info: Instantiated megafunction "pll:pll_100|altpll:altpll_component" with the following parameter:
        Info: Parameter "clk0_divide_by" = "2"
        Info: Parameter "clk0_duty_cycle" = "50"
        Info: Parameter "clk0_multiply_by" = "5"
        Info: Parameter "clk0_phase_shift" = "0"
        Info: Parameter "clk1_divide_by" = "4"
        Info: Parameter "clk1_duty_cycle" = "50"
        Info: Parameter "clk1_multiply_by" = "5"
        Info: Parameter "clk1_phase_shift" = "0"
        Info: Parameter "compensate_clock" = "CLK0"
        Info: Parameter "gate_lock_signal" = "NO"
        Info: Parameter "inclk0_input_frequency" = "20000"
        Info: Parameter "intended_device_family" = "Cyclone II"
        Info: Parameter "invalid_lock_multiplier" = "5"
        Info: Parameter "lpm_hint" = "CBX_MODULE_PREFIX=pll"
        Info: Parameter "lpm_type" = "altpll"
        Info: Parameter "operation_mode" = "NORMAL"
        Info: Parameter "port_activeclock" = "PORT_UNUSED"
        Info: Parameter "port_areset" = "PORT_USED"
        Info: Parameter "port_clkbad0" = "PORT_UNUSED"
        Info: Parameter "port_clkbad1" = "PORT_UNUSED"
        Info: Parameter "port_clkloss" = "PORT_UNUSED"
        Info: Parameter "port_clkswitch" = "PORT_UNUSED"
        Info: Parameter "port_configupdate" = "PORT_UNUSED"
        Info: Parameter "port_fbin" = "PORT_UNUSED"
        Info: Parameter "port_inclk0" = "PORT_USED"
        Info: Parameter "port_inclk1" = "PORT_UNUSED"
        Info: Parameter "port_locked" = "PORT_USED"
        Info: Parameter "port_pfdena" = "PORT_UNUSED"
        Info: Parameter "port_phasecounterselect" = "PORT_UNUSED"
        Info: Parameter "port_phasedone" = "PORT_UNUSED"
        Info: Parameter "port_phasestep" = "PORT_UNUSED"
        Info: Parameter "port_phaseupdown" = "PORT_UNUSED"
        Info: Parameter "port_pllena" = "PORT_USED"
        Info: Parameter "port_scanaclr" = "PORT_UNUSED"
        Info: Parameter "port_scanclk" = "PORT_UNUSED"
        Info: Parameter "port_scanclkena" = "PORT_UNUSED"
        Info: Parameter "port_scandata" = "PORT_UNUSED"
        Info: Parameter "port_scandataout" = "PORT_UNUSED"
        Info: Parameter "port_scandone" = "PORT_UNUSED"
        Info: Parameter "port_scanread" = "PORT_UNUSED"
        Info: Parameter "port_scanwrite" = "PORT_UNUSED"
        Info: Parameter "port_clk0" = "PORT_USED"
        Info: Parameter "port_clk1" = "PORT_USED"
        Info: Parameter "port_clk2" = "PORT_UNUSED"
        Info: Parameter "port_clk3" = "PORT_UNUSED"
        Info: Parameter "port_clk4" = "PORT_UNUSED"
        Info: Parameter "port_clk5" = "PORT_UNUSED"
        Info: Parameter "port_clkena0" = "PORT_UNUSED"
        Info: Parameter "port_clkena1" = "PORT_UNUSED"
        Info: Parameter "port_clkena2" = "PORT_UNUSED"
        Info: Parameter "port_clkena3" = "PORT_UNUSED"
        Info: Parameter "port_clkena4" = "PORT_UNUSED"
        Info: Parameter "port_clkena5" = "PORT_UNUSED"
        Info: Parameter "port_extclk0" = "PORT_UNUSED"
        Info: Parameter "port_extclk1" = "PORT_UNUSED"
        Info: Parameter "port_extclk2" = "PORT_UNUSED"
        Info: Parameter "port_extclk3" = "PORT_UNUSED"
        Info: Parameter "valid_lock_multiplier" = "1"
Info: Elaborating entity "lpm_add" for hierarchy "lpm_add:lpm"
Info: Elaborating entity "lpm_add_sub" for hierarchy "lpm_add:lpm|lpm_add_sub:lpm_add_sub_component"
Info: Elaborated megafunction instantiation "lpm_add:lpm|lpm_add_sub:lpm_add_sub_component"
Info: Instantiated megafunction "lpm_add:lpm|lpm_add_sub:lpm_add_sub_component" with the following parameter:
        Info: Parameter "lpm_direction" = "ADD"
        Info: Parameter "lpm_hint" = "ONE_INPUT_IS_CONSTANT=NO,CIN_USED=NO"
        Info: Parameter "lpm_pipeline" = "1"
        Info: Parameter "lpm_type" = "LPM_ADD_SUB"
        Info: Parameter "lpm_width" = "14"
Info: Found 1 design units, including 1 entities, in source file db/add_sub_omg.tdf
        Info: Found entity 1: add_sub_omg
Info: Elaborating entity "add_sub_omg" for hierarchy "lpm_add:lpm|lpm_add_sub:lpm_add_sub_component|add_sub_omg:auto_generated"
Error: Node instance "ux000" instantiates undefined entity "asj_altqmcpipe"
Error: Node instance "ux001" instantiates undefined entity "asj_dxx_g"
Error: Node instance "ux002" instantiates undefined entity "asj_dxx"
Error: Node instance "ux0219" instantiates undefined entity "asj_nco_apr_dxx"
Error: Node instance "ux008" instantiates undefined entity "asj_gam_dp"
Error: Node instance "ux0220" instantiates undefined entity "asj_nco_as_m_dp_cen"
Error: Node instance "ux0122" instantiates undefined entity "asj_nco_as_m_cen"
Error: Node instance "ux0123" instantiates undefined entity "asj_nco_as_m_cen"
Error: Node instance "m1" instantiates undefined entity "asj_nco_madx_cen"
Error: Node instance "m0" instantiates undefined entity "asj_nco_mady_cen"
Error: Node instance "ux0136" instantiates undefined entity "asj_nco_derot"
Error: Node instance "blk0" instantiates undefined entity "asj_nco_mob_w"
Error: Node instance "blk1" instantiates undefined entity "asj_nco_mob_w"
Error: Node instance "ux710isdr" instantiates undefined entity "asj_nco_isdr"
Error: Quartus II Analysis & Synthesis was unsuccessful. 28 errors, 267 warnings
        Error: Peak virtual memory: 175 megabytes
        Error: Processing ended: Thu Dec 17 15:46:05 2009
        Error: Elapsed time: 00:00:06
        Error: Total CPU time (on all processors): 00:00:03
Error: Quartus II Full Compilation was unsuccessful. 30 errors, 267 warnings
请各位大侠多多指教!
发表于 2009-12-24 10:13:20 | 只看该作者
2# bear
我前不久用过的。。。当时一切正常。。。。
发表于 2009-12-24 10:17:24 | 只看该作者
Info: Instantiated megafunction "pll:pll_100|altpll:altpll_component" with th ...
bear 发表于 2009-12-17 16:11
错误好像和那个小LPM_ADD有关吧,是不是路劲什么的问题啊,
其实你也可以把这个去掉了,看还会不会有错,不是非要用这个模块
而且ADA的驱动因为是超级简单的那种并行,给时钟出数据的那种
所以你自己也可以理解一下那个示例工程,不需要多在意细节
其实个人觉得那个示例工程有用的地方就是把引脚告诉你了。。。
PS:话说ADA用着还是很爽的。。如果能便宜点就好了。。
发表于 2009-12-25 13:59:24 | 只看该作者
我覺得應該是範例裡頭用的那個nco megafunction的問題,因為附的是早期版本的nco megafunction,但新版的Quartus只會安裝最新版本的nco megafunction,導致重新compile時找不到相對應的module而發生錯誤。
這種情況在我之前用Altera自己的DSP Kit時也有發生過,解決方法是自己更新並替換掉原來的nco megafunction,或是安裝舊版的nco megafuntion,反正這個範例就如同huguangheng所說的,重點是把相關的引腳都拉了出來給使用者。
至於ADA的售價 .. 老實說目前還沒有看到性價比高過它的,個人推測應該主要是卡在AD/DA IC的成本吧。
 楼主| 发表于 2010-1-4 19:44:39 | 只看该作者
huguangheng ,谢谢您的回复,LPM_ADD这个IP模块我重新的添加过,去除它也试过,问题还是老样子,问题可能还是出在NCO上,在QUARTUS II9.0 的环境底下可以重新的编译PLL和LPM的IP核,但是就是找不到NCO的IP核,可能是9.0的环境不支持实例中NCO的IP核?还有,要是你看到我的留言,可否告知你是用QUARTUS的什么版本跑那个范例的?
 楼主| 发表于 2010-1-4 19:55:06 | 只看该作者
5# dwcc
谢谢dwcc,我有研究了一下,问题可能和你说的差不多,你和“huguangheng”说的对,这个例子的重点是熟悉工程中的引脚应用,有问题再向你请教。
发表于 2010-1-4 22:56:34 | 只看该作者
7# bear
我用的8.1,后来没有更换过。
发表于 2010-1-11 22:05:18 | 只看该作者
经同意,转一位朋友的提问和我的回复如下,希望能有朋友进一步帮忙
我现在在使用贵公司的THDB_ADA子板卡配合DE2_70开发板做一个波形发生器,通过阅读THDB_ADA的DATASHEET,我知道了子板卡上数模转换芯片AD9767的引脚接法,但是就是不知道当THDB_ADA板卡通过GPIO扩展口接到DE2_70上时,芯片AD9767的引脚和GPIO0及GPIO1接口是怎么连的,即芯片的引脚是怎么一一对应连到GPIO的引脚的,通过THDB_ADA板卡附带的那张光盘中范例,我也看不出这些脚是怎么连的,只能去猜,下面的代码是DE2_70_ADA的那个范例的顶层文件,我把我对GPIO与DAC的相互连接的语句写上注释了,你帮我看看我理解的对不对的?
module DE2_70_TOP
  //////////////////// Clock Input   ////////////////////
  iCLK_28,      //  28.63636 MHz
  iCLK_50,      // 50 MHz
  iCLK_50_2,      // 50 MHz
  iCLK_50_3,      // 50 MHz
  iCLK_50_4,      // 50 MHz
  iEXT_CLOCK,      // External Clock
  //////////////////// Push Button  ////////////////////
  iKEY,       // Pushbutton[3:0]
  //////////////////// DPDT Switch  ////////////////////
  iSW,       // Toggle Switch[17:0]
  //////////////////// 7-SEG Dispaly ////////////////////
  oHEX0_D,      // Seven Segment Digit 0
  oHEX0_DP,      //  Seven Segment Digit 0 decimal point
  oHEX1_D,      // Seven Segment Digit 1
  oHEX1_DP,      //  Seven Segment Digit 1 decimal point
  oHEX2_D,      // Seven Segment Digit 2
  oHEX2_DP,      //  Seven Segment Digit 2 decimal point
  oHEX3_D,      // Seven Segment Digit 3
  oHEX3_DP,      //  Seven Segment Digit 3 decimal point
  oHEX4_D,      // Seven Segment Digit 4
  oHEX4_DP,      //  Seven Segment Digit 4 decimal point
  oHEX5_D,      // Seven Segment Digit 5
  oHEX5_DP,      //  Seven Segment Digit 5 decimal point
  oHEX6_D,      // Seven Segment Digit 6
  oHEX6_DP,      //  Seven Segment Digit 6 decimal point
  oHEX7_D,      // Seven Segment Digit 7
  oHEX7_DP,      //  Seven Segment Digit 7 decimal point
  //////////////////////// LED  ////////////////////////
  oLEDG,       // LED Green[8:0]
  oLEDR,       // LED Red[17:0]
  //////////////////////// UART ////////////////////////
  oUART_TXD,      // UART Transmitter
  iUART_RXD,      // UART Receiver
  oUART_CTS,             // UART Clear To Send
  iUART_RTS,             // UART Requst To Send
  //////////////////////// IRDA ////////////////////////
  oIRDA_TXD,      // IRDA Transmitter
  iIRDA_RXD,      // IRDA Receiver
  ///////////////////// SDRAM Interface  ////////////////
  DRAM_DQ,      // SDRAM Data bus 32 Bits
  oDRAM0_A,      // SDRAM0 Address bus 13 Bits
  oDRAM1_A,      // SDRAM1 Address bus 13 Bits
  oDRAM0_LDQM0,     // SDRAM0 Low-byte Data Mask
  oDRAM1_LDQM0,     // SDRAM1 Low-byte Data Mask
  oDRAM0_UDQM1,     // SDRAM0 High-byte Data Mask
  oDRAM1_UDQM1,     // SDRAM1 High-byte Data Mask
  oDRAM0_WE_N,     // SDRAM0 Write Enable
  oDRAM1_WE_N,     // SDRAM1 Write Enable
  oDRAM0_CAS_N,     // SDRAM0 Column Address Strobe
  oDRAM1_CAS_N,     // SDRAM1 Column Address Strobe
  oDRAM0_RAS_N,     // SDRAM0 Row Address Strobe
  oDRAM1_RAS_N,     // SDRAM1 Row Address Strobe
  oDRAM0_CS_N,     // SDRAM0 Chip Select
  oDRAM1_CS_N,     // SDRAM1 Chip Select
  oDRAM0_BA,      // SDRAM0 Bank Address
  oDRAM1_BA,       // SDRAM1 Bank Address
  oDRAM0_CLK,      // SDRAM0 Clock
  oDRAM1_CLK,      // SDRAM1 Clock
  oDRAM0_CKE,      // SDRAM0 Clock Enable
  oDRAM1_CKE,      // SDRAM1 Clock Enable
  //////////////////// Flash Interface  ////////////////
  FLASH_DQ,      // FLASH Data bus 15 Bits (0 to 14)
  FLASH_DQ15_AM1,     //  FLASH Data bus Bit 15 or Address A-1
  oFLASH_A,      // FLASH Address bus 26 Bits
  oFLASH_WE_N,     // FLASH Write Enable
  oFLASH_RST_N,     // FLASH Reset
  oFLASH_WP_N,     // FLASH Write Protect /Programming Acceleration
  iFLASH_RY_N,     // FLASH Ready/Busy output
  oFLASH_BYTE_N,     // FLASH Byte/Word Mode Configuration
  oFLASH_OE_N,     // FLASH Output Enable
  oFLASH_CE_N,     // FLASH Chip Enable
  //////////////////// SRAM Interface  ////////////////
  SRAM_DQ,      // SRAM Data Bus 32 Bits
  SRAM_DPA,       //  SRAM Parity Data Bus
  oSRAM_A,      // SRAM Address bus 22 Bits
  oSRAM_ADSC_N,          // SRAM Controller Address Status
  oSRAM_ADSP_N,                   // SRAM Processor Address Status
  oSRAM_ADV_N,                    // SRAM Burst Address Advance
  oSRAM_BE_N,                     // SRAM Byte Write Enable
  oSRAM_CE1_N,           // SRAM Chip Enable
  oSRAM_CE2,             // SRAM Chip Enable
  oSRAM_CE3_N,           // SRAM Chip Enable
  oSRAM_CLK,                      // SRAM Clock
  oSRAM_GW_N,            //  SRAM Global Write Enable
  oSRAM_OE_N,            // SRAM Output Enable
  oSRAM_WE_N,            // SRAM Write Enable
  //////////////////// ISP1362 Interface ////////////////
  OTG_D,       // ISP1362 Data bus 16 Bits
  oOTG_A,       // ISP1362 Address 2 Bits
  oOTG_CS_N,      // ISP1362 Chip Select
  oOTG_OE_N,      // ISP1362 Read
  oOTG_WE_N,      // ISP1362 Write
  oOTG_RESET_N,     // ISP1362 Reset
  OTG_FSPEED,      // USB Full Speed, 0 = Enable, Z = Disable
  OTG_LSPEED,      // USB Low Speed,  0 = Enable, Z = Disable
  iOTG_INT0,      // ISP1362 Interrupt 0
  iOTG_INT1,      // ISP1362 Interrupt 1
  iOTG_DREQ0,      // ISP1362 DMA Request 0
  iOTG_DREQ1,      // ISP1362 DMA Request 1
  oOTG_DACK0_N,     // ISP1362 DMA Acknowledge 0
  oOTG_DACK1_N,     // ISP1362 DMA Acknowledge 1
  //////////////////// LCD Module 16X2  ////////////////
  oLCD_ON,      // LCD Power ON/OFF
  oLCD_BLON,      // LCD Back Light ON/OFF
  oLCD_RW,      // LCD Read/Write Select, 0 = Write, 1 = Read
  oLCD_EN,      // LCD Enable
  oLCD_RS,      // LCD Command/Data Select, 0 = Command, 1 = Data
  LCD_D,      // LCD Data bus 8 bits
  //////////////////// SD_Card Interface ////////////////
  SD_DAT,       // SD Card Data
  SD_DAT3,      // SD Card Data 3
  SD_CMD,       // SD Card Command Signal
  oSD_CLK,      // SD Card Clock
  //////////////////// I2C  ////////////////////////////
  I2C_SDAT,      // I2C Data
  oI2C_SCLK,      // I2C Clock
  //////////////////// PS2  ////////////////////////////
  PS2_KBDAT,      // PS2 Keyboard Data
  PS2_KBCLK,      // PS2 Keyboard Clock
  PS2_MSDAT,      // PS2 Mouse Data
  PS2_MSCLK,      // PS2 Mouse Clock
  //////////////////// VGA  ////////////////////////////
  oVGA_CLOCK,        // VGA Clock
  oVGA_HS,      // VGA H_SYNC
  oVGA_VS,      // VGA V_SYNC
  oVGA_BLANK_N,     // VGA BLANK
  oVGA_SYNC_N,     // VGA SYNC
  oVGA_R,         // VGA Red[9:0]
  oVGA_G,        // VGA Green[9:0]
  oVGA_B,        // VGA Blue[9:0]
  //////////// Ethernet Interface ////////////////////////
  ENET_D,      // DM9000A DATA bus 16Bits
  oENET_CMD,      // DM9000A Command/Data Select, 0 = Command, 1 = Data
  oENET_CS_N,      // DM9000A Chip Select
  oENET_IOW_N,     // DM9000A Write
  oENET_IOR_N,     // DM9000A Read
  oENET_RESET_N,     // DM9000A Reset
  iENET_INT,      // DM9000A Interrupt
  oENET_CLK,      // DM9000A Clock 25 MHz
  //////////////// Audio CODEC  ////////////////////////
  AUD_ADCLRCK,     // Audio CODEC ADC LR Clock
  iAUD_ADCDAT,     // Audio CODEC ADC Data
  AUD_DACLRCK,     // Audio CODEC DAC LR Clock
  oAUD_DACDAT,     // Audio CODEC DAC Data
  AUD_BCLK,      // Audio CODEC Bit-Stream Clock
  oAUD_XCK,      // Audio CODEC Chip Clock
  //////////////// TV Decoder  ////////////////////////
  iTD1_CLK27,      // TV Decoder1 Line_Lock Output Clock
  iTD1_D,             // TV Decoder1 Data bus 8 bits
  iTD1_HS,      // TV Decoder1 H_SYNC
  iTD1_VS,      // TV Decoder1 V_SYNC
  oTD1_RESET_N,     // TV Decoder1 Reset
  iTD2_CLK27,      // TV Decoder2 Line_Lock Output Clock
  iTD2_D,             // TV Decoder2 Data bus 8 bits
  iTD2_HS,      // TV Decoder2 H_SYNC
  iTD2_VS,      // TV Decoder2 V_SYNC
  oTD2_RESET_N,     // TV Decoder2 Reset
  //////////////////// GPIO ////////////////////////////
  GPIO_0,       // GPIO Connection 0 I/O
  GPIO_CLKIN_N0,         // GPIO Connection 0 Clock Input 0
  GPIO_CLKIN_P0,            // GPIO Connection 0 Clock Input 1
  GPIO_CLKOUT_N0,        // GPIO Connection 0 Clock Output 0
  GPIO_CLKOUT_P0,                 // GPIO Connection 0 Clock Output 1
  GPIO_1,       // GPIO Connection 1 I/O
  GPIO_CLKIN_N1,                  // GPIO Connection 1 Clock Input 0
  GPIO_CLKIN_P1,                  // GPIO Connection 1 Clock Input 1
  GPIO_CLKOUT_N1,                 // GPIO Connection 1 Clock Output 0
  GPIO_CLKOUT_P1                  // GPIO Connection 1 Clock Output 1
        ,sin_out
        ,sin10_out
        ,comb               //从sin_out---CLK_100这6个信号在QSF文件中看,并没有引脚的分配,
        ,a2dba              //为什么要写在顶层的端口列表中呢? 而不是以中间信号REG或WIRE             ,a2dbb              //的形式写端口列表外面呢?  这样写有什么作用?
        ,CLK_100
发表于 2010-1-11 22:08:02 | 只看该作者
***省略***
// REG/WIRE declarations
output  [13:0]a2dba; //这个信号用来干嘛?是用于信号的反馈测试吗?
output  [13:0]a2dbb; //这个信号用来干嘛?是用于信号的反馈测试吗?
//assign  a2db = {GPIO_0[14],GPIO_0[15],GPIO_0[16],GPIO_0[18],GPIO_0[17],GPIO_0[19],GPIO_0[20],GPIO_0[22],
                //GPIO_0[21],GPIO_0[23],GPIO_0[24],GPIO_0[26],GPIO_0[25],GPIO_0[27]};
assign  a2dba = {GPIO_0[27],GPIO_0[25],GPIO_0[26],GPIO_0[24],GPIO_0[23],GPIO_0[21],GPIO_0[22],GPIO_0[20],
                 GPIO_0[19],GPIO_0[17],GPIO_0[18],GPIO_0[16],GPIO_0[15],GPIO_0[14]};
assign  a2dbb = {GPIO_0[13],GPIO_0[11],GPIO_0[12],GPIO_0[10],GPIO_0[9],GPIO_0[7],GPIO_0[8],GPIO_0[6],
                 GPIO_0[5],GPIO_0[3],GPIO_0[4],GPIO_0[2],GPIO_0[1],GPIO_0[0]};
assign  {GPIO_1[15],GPIO_1[17],GPIO_1[18],GPIO_1[20],GPIO_1[19],GPIO_1[21],GPIO_1[23],GPIO_1[25],
         GPIO_1[22],GPIO_1[24],GPIO_1[27],GPIO_1[29],GPIO_1[26],GPIO_1[28]} = comb; //接到DAC数据输入端口B
assign  {GPIO_1[0],GPIO_1[1],GPIO_1[2],GPIO_1[4],GPIO_1[3],GPIO_1[5],GPIO_1[6],GPIO_1[8],
         GPIO_1[7],GPIO_1[9],GPIO_1[10],GPIO_1[12],GPIO_1[11],GPIO_1[13]} = comb; //接到DAC数据输入端口A
assign  GPIO_1[30] = CLK_125; //Input write signal for PORT B  接到DAC的WRT1端口
assign  GPIO_1[14] = CLK_125; //Input write signal for PORT A  接到DAC的WRT2端口
assign  GPIO_1[31] = 1; //Mode Select. 1 = dual port, 0 = interleaved. 接到DAC的Mode
assign  GPIO_0[28] = 1; //POWER ON  电源有效?
assign  GPIO_0[29] = 0; //Enable B  这个AD9767芯片有低电平有效的使能信号吗?
assign  GPIO_0[31] = 0; //Enable A  这个AD9767芯片有低电平有效的使能信号吗
output    CLK_100;  // 这个CLK_100写的是输出端口,但是它哪里也没有接,它是用来干嘛的?
wire    [31:0]phasinc1;
wire    [31:0]phasinc2;
wire    g = 0;
wire    v = 1;
assign  phasinc1 = {g,g,g,g,v,v,g,g,v,v,g,g,v,v,g,g,v,v,g,g,v,v,g,g,v,v,g,g,v,v,g,v}; //用于NCO231产生振波
assign  phasinc2 = {g,v,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g,g}; //形数据?
output  [13:0]sin10_out;
output  [13:0]sin_out;
wire    sn;
wire    s10n;
assign  sn      = ~sin_out[12];
assign  s10n    = ~sin10_out[12];
assign  GPIO_CLKOUT_P1 = CLK_125; //PLL Clock to DAC_B 接到DAC的通路B的CLK?
assign  GPIO_CLKOUT_N1 = CLK_125; //PLL Clock to DAC_A 接到DAC通路A的CLK?
assign  GPIO_CLKOUT_P0 = CLK_65; //PLL Clock to ADC_B
assign  GPIO_CLKOUT_N0 = CLK_65; //PLL Clock to ADC_A
output  [13:0]comb;
// Structural coding
nco231  sin1    (.phi_inc_i(phasinc1),
                 .clk(CLK_125),
                 .clken(v),
                 .reset_n(g),
                 .fsin_o(sin_out),
                 .out_valid(ovalid));
nco231  sin2    (.phi_inc_i(phasinc2),
                 .clk(CLK_125),
                 .clken(v),
                 .reset_n(g),
                 .fsin_o(sin10_out),
pll     pll_100 (.inclk0(iCLK_50),
                 .pllena(v),
                 .areset(g),
                 .c0(CLK_125),
                 .c1(CLK_65));
lpm_add lpm     (.clock(CLK_125),
                 .dataa({g,sn,sin_out[11:0]}), // 为什么sn要写成 sn = ~sin_out[12];???
                 .datab({g,s10n,sin10_out[11:0]}),//这个输入数据为什么最高位要取0呢?
                 .result(comb));    //输出数据应该是14BIT的普通数据吧,有什么约束吗?
//assign  comb = (iSW[17]) ? (iSW[16]) ? (iSW[15]) ? {sn,sin_out[12:0]} : tri_data : ramp_data : square;
    因为我是第一次用DAC,所以对它的参数理解不是很深刻,还有一个问题就是THDB_ADA子板卡上的AD9767 DAC芯片的最大采样率是125MSPS,那么它的最高工作频率是用125MSPS这个参数通过“采样公式”计算125*0.5= 62.5 MHZ?还是芯片使用手册上所写的40MHZ呢?根据我看的资料,DAC芯片的最大工作频率是由芯片的“Maximum Output Update Rate (fCLK) ”决定的,那么AD9767的 Maximum Output Update Rate (fCLK) 是125MHZ,那这是否又意味着芯片的最高工作频率是125MHZ呢?总结这个问题就是板卡上所用的AD9767的最高工作频率是多少?40MHZ?65MHZ?还是125MHZ?这个最高工作频率到底是怎么算出来的,由芯片的什么参数决定呢,这个问题搞的我都有点晕了,如果可以,也请你帮我看一下。
发表于 2010-1-11 22:08:36 | 只看该作者
转一下我的回复,
关于ADA,因为我当初用得是3C120的开发板,所以引脚和DE2-70不一样,无法直接把代码给你看。如果希望弄清楚引脚的连接,需要参考DE2-70和ADA的datasheet,以及DE2-70的范例中的qsf里的引脚设置。从sch图中可以得到结果
关于接口。除了数据和时钟外,有低电平有效的使能信号,以及一个power_on,至于inter模式,我当初没有使用,所以不清楚引脚情况。
仔细看光盘中的内容,尤其是性能评估的那份资料,里面有信噪比的那个,你会发现有清楚地讲到这个范例是用NCO,LPM_ADD先生成信号,再由DA输出,AD采集,并分析其信号质量。(ps,这也是个联合测量AD,DA的好办法)
关于数据输出的处理。我没有仔细分析。。大概猜了下,
对于“纯正”信号:如果是我要提供待测试的数字信源,首先要避免数据溢出,考虑src和snk端的数据格式不同,比如符号位。如果考虑snk端特性(比如对于AD,希望信源幅度和频率都能在信噪比相对高的范围内),比如,在无放大的情况下,数字端就让数据处于比较合适的幅度。
对于产生“特别”的波形:比如为了产生多个频率和不同程度谐波,以及产生缓变和陡变信号,甚至毛刺和震荡之类。。(扯远了。。),可以在bus输出端里简单的调整一下特定bit,这样在定性不定量的简单测试中比做一个复杂的新源还是方便得多
不过以上我都瞎猜的,没有仔细想啊。。。
关于最后那个AD,DA,实际能工作在多少,首先,理论上是2倍信号频率的时钟就可以,即一个周期采2个点,理论上可以复原信号。但是实际中大部分时候都不会这样,相信如果你自己试过的话,就印象更深刻了。
比如说你可以使用NCO的IP,然后在配置参数时,在固定系统时钟下,即fs下,输出信号的频率从低到高,直到逼近1/2系统时钟时,输出信号的信噪会怎么变化。可以自己玩一下 : )
那么到底,系统/采样时钟和信号的比例是多少,根据不同系统来定。你可以参考DSP原理的书,或者看ADI啊,Linear等的AD/DA设计及选型方案。或者直接看信号质量你系统中相邻的模块能不能接受罗,比如用DA输出正弦波,再用模拟filter来还原,低频下,根据信号还原的要求和滤波器制作难度,数字部分一般最少会4~10倍采样,不过模拟的人可能要有意见了,那么就可能会提高几倍,甚至数量级,如果模拟部分处理得很好,甚至数字部分本身就还有一些模块来提高信噪比,那么也有极端到2.5倍的。
最后
TO 友晶的大大们
我觉得呢。。随着大陆这边越来越多的人选择友晶的母版及子卡。
或许更全面及亲切的入门手册及指导书是有意义的
其中,也还是考虑一下大陆这边的情况罗 : )
可能在TaiWan,这个已经很入门了。。但是我自己也觉得。。
当初在用DE开发板及子卡的时候,还是希望能有个更入门更详细的指导书呢 : )
谢谢了哟,嘿嘿
发表于 2010-1-12 01:07:44 | 只看该作者
“最后
TO 友晶的大大们
谢谢了哟,嘿嘿”
好建议!
发表于 2010-1-20 00:47:19 | 只看该作者
各位大大们,我最近做毕业设计,需要在硬件上演示,用的是Cyclone III starter board
说实话,我现在都不是很懂这些东西,不知道能不能讲清,我的情况是这样的
想要演示的是一个VHDL的程序,其输出是I[7..0]   I_clk           Q[7..0]     Q_clk,也就是I,Q两路8位数字信号和对应的时钟。目的是通过DA变化把信道输出到频谱仪上把输出信号演示
用到的器材是Cyclone III starter board,THDB_ADA
现在碰到的问题是不知道怎么配置管脚,我现在有CIII_Starter_Kit的示例工程,但是看不太懂,求高手指教
发表于 2010-1-20 00:55:43 | 只看该作者
我的QQ:282965382   邮箱nicebuidlings@gmail.com  希望高手指教
如果我问题没说清的话 需要什么资料我可以通过邮箱发过去,谢谢
GMT+8, 2026-11-3 09:02 , Processed in 0.039253 second(s), 18 queries .
