查看: 9589|回复: 1
VHDL 描述的自较验测试的简单例子
发表于 2010-3-3 11:38:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在VHDL中,向量文件包含预期的结果。VHDL 的textio程序包用于从向量文件中读取数据,和显示错误信息。这个测试用VHDL示例秒表设计.
LIBRARY IEEE;
USE IEEE.std_logic_1164.all;
LIBRARY ieee;
USE IEEE.STD_LOGIC_TEXTIO.ALL;
USE STD.TEXTIO.ALL;
ENTITY testbench IS
END testbench;
ARCHITECTURE testbench_arch OF testbench IS
COMPONENT stopwatch
PORT (
CLK : in STD_LOGIC;
RESET : in STD_LOGIC;
STRTSTOP : in STD_LOGIC;
TENTHSOUT : out STD_LOGIC_VECTOR (9 DOWNTO 0);
ONESOUT : out STD_LOGIC_VECTOR (6 DOWNTO 0);
TENSOUT : out STD_LOGIC_VECTOR (6 DOWNTO 0)
END COMPONENT;
SIGNAL CLK : STD_LOGIC;
SIGNAL RESET : STD_LOGIC;
SIGNAL STRTSTOP : STD_LOGIC;
SIGNAL TENTHSOUT : STD_LOGIC_VECTOR (9 DOWNTO 0);
SIGNAL ONESOUT : STD_LOGIC_VECTOR (6 DOWNTO 0);
SIGNAL TENSOUT : STD_LOGIC_VECTOR (6 DOWNTO 0);
constant ClockPeriod : Time := 60 ns;
FILE RESULTS: TEXT IS OUT "results.txt";
signal i: std_logic;
BEGIN
UUT : stopwatch
PORT MAP (
CLK => CLK,
RESET => RESET,
STRTSTOP => STRTSTOP,
TENTHSOUT => TENTHSOUT,
ONESOUT => ONESOUT,
TENSOUT => TENSOUT
stimulus: PROCESS
reset <= ’1’;
strtstop <= ’1’;
wait for 240 ns;
reset <= ’0’;
strtstop <= ’0’;
wait for 5000 ns;
strtstop <= ’1’;
wait for 8125 ns;
strtstop <= ’0’;
wait for 500 ns;
strtstop <= ’1’;
wait for 875 ns;
reset <= ’1’;
wait for 375 ns;
reset <= ’0’;
wait for 700 ns;
strtstop <= ’0’;
wait for 550 ns;
strtstop <= ’1’;
end process stimulus;
clock: process
clk <= ’1’;
wait for 100 ns;
loop
wait for (ClockPeriod / 2);
CLK <= not CLK;
end loop;
end process clock;
check_results : process
variable tmptenthsout: std_logic_vector(9 downto 0);
variable l: line;
variable good_val, good_number, errordet: boolean;
variable r : real;
variable vector_time: time;
variable space: character;
file vector_file: text is in "values.txt";
while not endfile(vector_file) loop
readline(vector_file, l);
read(l, r, good => good_number);
next when not good_number;
vector_time := r * 1 ns;
if (now < vector_time) then
wait for vector_time - now;
end if;
read(l, space);
read(l, tmptenthsout, good_val);
assert good_val REPORT "bad tenthsoutvalue";
wait for 10 ns;
if (tmptenthsout /= tenthsout) then
assert errordet REPORT "vector mismatch";
end if;
end loop;
wait;
end process check_results;
end testbench_arch;
library XilinxCoreLib;
CONFIGURATION stopwatch_cfg OF testbench IS
FOR testbench_arch
FOR ALL : stopwatch use configuration work.cfg_tenths;
END FOR;
END FOR;
END stopwatch_cfg;
以下向量文件用于上述的测试。它包含了预期的仿真值。
-- Vector file containing expected results
0 1111111110
340 1111111110
400 1111111101
460 1111111011
520 1111110111
580 1111101111
640 1111011111
700 1110111111
760 1101111111
820 1011111111
880 0111111111
940 1111111110
1000 1111111110
1060 1111111101
1120 1111111011
1180 1111110111
1240 1111101111
1300 1111011111
1360 1110111111
1420 1101111111
1480 1011111111
1540 0111111111
1600 1111111110
1660 1111111110
1720 1111111101
1780 1111111011
如果错误被检测到,它会显示在一个仿真提示器中显示。
发表于 2011-7-28 14:13:07 | 只看该作者
顶
不错,顶顶顶,呵呵!
GMT+8, 2026-11-2 05:07 , Processed in 0.035576 second(s), 14 queries .
