查看: 5417|回复: 0
Verilog 描述的自较验测试的简单例子
发表于 2010-3-3 11:36:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
下述的设计实例中,预期的结果被详细说明。后面的代码,两种结果被比较,比较的结果被返回终端。如果没有错误,一个“end of good simulation”消息会显示。如果失配发生,根据期望与实际值的失配情况,错误会被相应报告。
‘timescale 1 ns / 1 ps
module test_sc;
reg tbreset, tbstrtstop;
reg tbclk;
wire [6:0] onesout, tensout;
wire [9:0] tbtenthsout;
parameter cycles = 25;
reg [9:0] Data_in_t [0:cycles];
// Instantiation of the Design
stopwatch UUT (.CLK (tbclk), .RESET (tbreset), .STRTSTOP (tbstrtstop),
.ONESOUT (onesout), .TENSOUT (tensout), .TENTHSOUT (tbtenthsout));
wire [4:0] tbonesout, tbtensout;
assign tbtensout = led2hex(tensout);
assign tbonesout = led2hex(onesout);
//EXPECTED RESULTS
initial begin
Data_in_t[1] =10’b1111111110;
Data_in_t[2] =10’b1111111101;
Data_in_t[3] =10’b1111111011;
Data_in_t[4] =10’b1111110111;
Data_in_t[5] =10’b1111101111;
Data_in_t[6] =10’b1111011111;
Data_in_t[7] =10’b1110111111;
Data_in_t[8] =10’b1101111111;
Data_in_t[9] =10’b1011111111;
Data_in_t[10]=10’b0111111111;
Data_in_t[11]=10’b1111111110;
Data_in_t[12]=10’b1111111110;
Data_in_t[13]=10’b1111111101;
Data_in_t[14]=10’b1111111011;
Data_in_t[15]=10’b1111110111;
Data_in_t[16]=10’b1111101111;
Data_in_t[17]=10’b1111011111;
Data_in_t[18]=10’b1110111111;
Data_in_t[19]=10’b1101111111;
Data_in_t[20]=10’b1011111111;
Data_in_t[21]=10’b0111111111;
Data_in_t[22]=10’b1111111110;
Data_in_t[23]=10’b1111111110;
Data_in_t[24]=10’b1111111101;
Data_in_t[25]=10’b1111111011;
reg GSR;
assign glbl.GSR = GSR;
initial begin
GSR = 1;
// Wait till Global Reset Finished
#100 GSR = 0;
// Create the clock
initial begin
tbclk = 0;
// Wait till Global Reset Finished, then cycle clock
#100 forever #60 tbclk = ~tbclk;
initial begin
// Initialize All Input Ports
tbreset = 1;
tbstrtstop = 1;
// Apply Design Stimulus
#240 tbreset = 0;
tbstrtstop = 0;
#5000 tbstrtstop = 1;
#8125 tbstrtstop = 0;
#500 tbstrtstop = 1;
#875 tbreset = 1;
#375 tbreset = 0;
#700 tbstrtstop = 0;
#550 tbstrtstop = 1;
// simulation must be halted inside an initial statement
// #100000 $stop;
integer i,errors;
// Block below compares the expected vs. actual results
// at every negative clock edge.
always @ (posedge tbclk)
if (tbstrtstop)
i = 0;
errors = 0;
for (i = 1; i <= cycles; i = i + 1)
@(negedge tbclk)
// check result at negedge
$display("Time%d ns; TBSTRTSTOP=%b; Reset=%h; Expected
TenthsOut=%b; Actual TenthsOut=%b", $stime, tbstrtstop, tbreset,
Data_in_t, tbtenthsout);
if ( tbtenthsout !== Data_in_t )
$display(" ------ERROR. A mismatch has occurred-----");
errors = errors + 1;
if (errors == 0)
$display("Simulation finished Successfully.");
else if (errors > 1)
$display("%0d ERROR! See log above for details.",errors);
$display("ERROR! See log above for details.");
#100 $stop;
这种简单的自较验测试设计可以转换到任何测试场合----当然,预期的输出值和信号的名字在重用时是需要更改的。如果不需要每个时钟沿检查,需要的话可以修改for-loop结构。
GMT+8, 2026-3-17 02:08 , Processed in 0.044076 second(s), 14 queries .
