查看: 6268|回复: 0
简单的测试设计 (Verilog)
发表于 2010-3-1 09:21:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下是用Verilog实现移位寄存器的功能。
module shift_reg (clock, reset, load, sel, data, shiftreg);
input clock;
input reset;
input load;
input [1:0] sel;
input [4:0] data;
output [4:0] shiftreg;
reg [4:0] shiftreg;
always @ (posedge clock)
if (reset)
shiftreg = 0;
else if (load)
shiftreg = data;
case (sel)
2’b00 : shiftreg = shiftreg;
2’b01 : shiftreg = shiftreg << 1;
2’b10 : shiftreg = shiftreg >> 1;
default : shiftreg = shiftreg;
endcase
以下是简单的测试设计示例移位寄存器设计的例子。
module testbench; // declare testbench name
reg clock;
reg load;
reg reset; // declaration of signals
wire [4:0] shiftreg;
reg [4:0] data;
reg [1:0] sel;
// instantiation of the shift_reg design below
shift_reg dut(.clock (clock),
.load (load),
.reset (reset),
.shiftreg (shiftreg),
.data (data),
.sel (sel));
//this process block sets up the free running clock
initial begin
clock = 0;
forever #50 clock = ~clock;
initial begin// this process block specifies the stimulus.
reset = 1;
data = 5’b00000;
load = 0;
sel = 2’b00;
#200
reset = 0;
load = 1;
#200
data = 5’b00001;
#100
sel = 2’b01;
load = 0;
#200
sel = 2’b10;
#1000 $stop;
initial begin// this process block pipes the ASCII results to the
//terminal or text editor
$timeformat(-9,1,"ns",12);
$display(" Time Clk Rst Ld SftRg Data Sel");
$monitor("%t %b %b %b %b %b %b", $realtime,
clock, reset, load, shiftreg, data, sel);
以上的测试设计实例化设计,设置时钟,提供激励信号。所有的进程块在仿真时间零点开始。英镑标记(#)说明下一个激励作用前的延迟。$stop命令使仿真器停止测试仿真(所有测试设计中都应该包含一个停止命令)。最后,$monitor语句返回ascII格式的结果到屏幕或者管道输出到一个文本编辑器。
GMT+8, 2026-3-17 02:15 , Processed in 0.040171 second(s), 14 queries .
