查看: 7715|回复: 0
nios II 读写 CFI_FLash
发表于 2010-8-27 13:19:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <stdio.h>
#include "io.h"
#include "system.h"
#include "alt_types.h"
#include "sys/alt_flash.h"
#include "sys/alt_flash_dev.h"
#include "altera_avalon_pio_regs.h"
void test_flash_block();
void test_flash_bytes();
int main()
    test_flash_bytes();
        return 0;
//按字节来读写
    alt_flash_fd *my_flash; //define handle
    flash_region* regions;
    int number_of_regions;
    int ret_code ;
    my_flash = alt_flash_open_dev(CFI_FLASH_NAME);//open flash, get handle
    if(my_flash == NULL)
        printf("Open flash fail \n");
        return 0;
    char buf[]="Hello world!";
    int  nAddr = 0x0;
    int  tempAddr = nAddr;
    ret_code = alt_get_flash_info (my_flash, &regions, &number_of_regions);
    if(my_flash != NULL)
        int j = 0;
        for(j=0;j<number_of_regions;j++)
            printf("regions[%d].offset = %d \n", j, regions[j].offset);
            printf("regions[%d].region_size = %d \n", j, regions[j].region_size);
            printf("regions[%d].number_of_blocks = %d\n", j, regions[j].number_of_blocks);
            printf("regions[%d].block_size = %d \n\n", j, regions[j].block_size);
        printf("get flash info fail \n");
//    ret_code = alt_write_flash(my_flash,nAddr,buf,sizeof(buf));
//    memset(buf,0, sizeof(buf));
//    alt_read_flash(my_flash, tempAddr, buf, sizeof(buf));
//    printf("%s",buf);
   int i=0;
   for(i=0;i<sizeof(buf);i++, nAddr++)
    ret_code = alt_write_flash(my_flash,nAddr,&buf[i],1);
    usleep(100*1000);
    if(ret_code != 0)
        printf("write flash fail \n");
        return 0;
    memset(buf, 0,sizeof(buf));
    for(i=0;i<sizeof(buf);i++, tempAddr++)
      alt_read_flash(my_flash, tempAddr, &buf[i], 1);
      printf("%c", buf[i]);
    alt_flash_close_dev(my_flash);
//按块来读写
    int ret_code ;
    char *buf = NULL;
        return;
        int j = 0;
            printf("\n******************regions %d*************************\n",j);
            buf = (char*)malloc(regions[j].block_size);
            memset(buf, 'a', regions[j].block_size);
            ret_code = alt_write_flash(my_flash,regions[j].offset,buf,regions[j].block_size);
            if(ret_code != 0)
                 return;
            memset(buf,0, regions[j].block_size);
            ret_code = alt_read_flash(my_flash, regions[j].offset, buf, regions[j].block_size);
            if(ret_code != 0)
                printf("read flash fail \n");
                return;
            int i=0;
            for(i=0;i< 20 ;i++)
                printf("%c",buf[i]);
            free(buf);
GMT+8, 2026-10-16 07:26 , Processed in 0.033804 second(s), 15 queries .
