查看: 5053|回复: 2
DE0 connecting pins to board switches
发表于 2010-6-6 20:57:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
hi
I need some help with my DE0 board. I did a schematic in quartis II following the "Quartis II introduction using schematic design" for the DE2 board. However I got stuck at the assignment editor where I want to assign input and output pins between my design and board. (page 17 figure 24) where it says "under category, select pin" I cannot find "pin". There are only iobank; iostandard etc. I am using Quartis II (9.1 service pack 2 free edition) can anyone help.
thanks
Gerhard
发表于 2010-7-19 08:55:38 | 只看该作者
sorry I cannot understang you
发表于 2010-7-19 22:10:56 | 只看该作者
回复 1# jacobsg
    Hi,Gerhard I think you can use the forum's "FPGA 设计工具",
"Quartus Project 產生軟體"
http://www.myfpga.org/discuz/vie ... 2393&highlight=
Can be fix your problem.
There has  "Terasic_system_builder_v008" software can create have I/O Pin 's DE0 Project, you just need choice you that want  component.
Use the Software after,you can start to design the project.. If you want to move the DE2 example project  to DE0. I think it's the other way..
Sorry my english is not very well.. Good Luck!
GMT+8, 2026-10-16 04:28 , Processed in 0.036251 second(s), 15 queries .
