查看: 4626|回复: 0
QuartusII中编译出现的问题,求助!!
发表于 2009-8-10 09:51:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请大家帮我分析一下我的程序中的错误,万分感谢!!
我想对memory型变量进行操作。
下面是我的程序:
module xinsuoyin (dataa,result);
input[5:0] dataa;
output[9:0] result;
reg[9:0] ramzhong;
reg[9:0]  result;
reg[6:0]  i;
(*ram_init_file = "cpu_ic_tag_ram.mif"*) reg [9:0] ram[63:0];
always@(dataa)
    for(i=0;i<=63;i=i+1)
        ramzhong[9:0]=ram;
        if(ramzhong[9:4]==dataa[5:0])
            result[3:0]=ramzhong[3:0];
            result[9:4]=6'b0;
附:(编译信息)
Warning (10030): Net "ram[0][9]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][8]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][7]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][6]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][5]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][4]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][3]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][2]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][1]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
Warning (10030): Net "ram[0][0]" at xinsuoyin.v(7) has no driver or initial value, using a default initial value '0'
GMT+8, 2026-11-24 22:13 , Processed in 0.035348 second(s), 15 queries .
