查看: 5584|回复: 0
【FAQ】TSP测试openvino案例报错Cannot find any Intel FPGA board libraries
发表于 2022-10-20 18:15:13 | 显示全部楼层 |阅读模式
Q:参考 Install_TSP_OpenVINO_Development_Environment_on_PC_with_ISO_Image.pdf启动系统以后,按照《2019师资培训OpenVINO实验手册_for_OSK.pdf》 测试Openvino demo 案例报错:
Warming: Cannot find any Intel (R) FPGA board libraries. No Intel(R) FPGA devices will loaded. Please contact your board vender or see section "Linking Your Host Application to the Khronos ICD Loader Library" of the Programming Guide to set up FCD manually.
ERROR:UNRECOGNISED ERROR CODE(-1001)
A: 请先参考FAQ:http://www.myfpga.org/discuz/for ... D1&from_wecom=1
然后 请输入下面四个命令。
1. source setup_board_tsp.sh
2. sudo rm /opt/Intel -rf
3. aocl install
4. aocl diagnose
注意:sudo rm /opt/Intel -rf  注意是大写Intel,如果搞成了小写,那就把Openvino 全删了  就恢复不了了。
GMT+8, 2026-11-16 21:13 , Processed in 0.037603 second(s), 21 queries .
