查看: 5311|回复: 0
【FAQ】测试OpenCL,执行aocl flash报错Flash Loader IP not loaded
发表于 2022-5-19 17:49:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Q: 测试DE10-Agilex官网的v21.2 OpenCL BSP,OpenCL驱动安装正确,lspci能看到设备:lspci: "0000:01:00.0 Processing accelerators: Altera Corporation Device 35b4 (rev 01)"
aocl diagnose也成功:
但是执行aocl flash命令后报错:
Error (209062): Flash Loader IP not loaded on device 0
Error (209053): Unexpected error in JTAG server -- error code 5
Error (209031): Device chain in Chain Description File does not match physical device chain -- expected 2 device(s) but found 1 device(s).
A: 这应该是拨码开关SW9设置有问题,System MAX器件不在JTAG链路中;需将SW9拨到OFF位置,如下图所示。
GMT+8, 2026-9-9 19:04 , Processed in 0.067992 second(s), 18 queries .
