查看: 7095|回复: 0
【FAQ】设置完qsys以后编译工程提示Error (12006)
发表于 2021-9-15 16:29:07 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Q:设置完qsys以后编译工程提示:Error (12006): Node instance "u0" instantiates undefined entity "nios2_system". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
A: 您这是忘记了把.qsys文件添加到assignments ——> settings里面去:
GMT+8, 2026-9-29 07:06 , Processed in 0.070149 second(s), 18 queries .
