查看: 10312|回复: 4
rs232串口问题
发表于 2010-5-22 10:47:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
// RS-232 TX module
// (c) fpga4fun.com KNJN LLC - 2003, 2004, 2005, 2006
//`define DEBUG   // in DEBUG mode, we output one bit per clock cycle (useful for faster simulations)
module async_transmitter(clk, TxD_start, TxD_data, TxD, TxD_busy);
input clk, TxD_start;
input [7:0] TxD_data;
output TxD, TxD_busy;
parameter ClkFrequency = 25000000;        // 25MHz
parameter Baud = 9600;//115200;
parameter RegisterInputData = 1;        // in RegisterInputData mode, the input doesn't have to stay valid while the character is been transmitted
// Baud generator
parameter BaudGeneratorAccWidth = 16;
reg [BaudGeneratorAccWidth:0] BaudGeneratorAcc;
`ifdef DEBUG
wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = 17'h10000;
`else
wire [BaudGeneratorAccWidth:0] BaudGeneratorInc = ((Baud<<(BaudGeneratorAccWidth-4))+(ClkFrequency>>5))/(ClkFrequency>>4);
`endif
wire BaudTick = BaudGeneratorAcc[BaudGeneratorAccWidth];
wire TxD_busy;
always @(posedge clk) if(TxD_busy) BaudGeneratorAcc <= BaudGeneratorAcc[BaudGeneratorAccWidth-1:0] + BaudGeneratorInc;
// Transmitter state machine
reg [3:0] state;
wire TxD_ready = (state==0);
assign TxD_busy = ~TxD_ready;
reg [7:0] TxD_dataReg;
always @(posedge clk) if(TxD_ready & TxD_start) TxD_dataReg <= TxD_data;
wire [7:0] TxD_dataD = RegisterInputData ? TxD_dataReg : TxD_data;
case(state)
        4'b0000: if(TxD_start)state <= 4'b0001;
        4'b0001: if(BaudTick) state <= 4'b0100;
        4'b0100: if(BaudTick) state <= 4'b1000;  // start
        4'b1000: if(BaudTick) state <= 4'b1001;  // bit 0
        4'b1001: if(BaudTick) state <= 4'b1010;  // bit 1
        4'b1010: if(BaudTick) state <= 4'b1011;  // bit 2
        4'b1011: if(BaudTick) state <= 4'b1100;  // bit 3
        4'b1100: if(BaudTick) state <= 4'b1101;  // bit 4
        4'b1101: if(BaudTick) state <= 4'b1110;  // bit 5
        4'b1110: if(BaudTick) state <= 4'b1111;  // bit 6
        4'b1111: if(BaudTick) state <= 4'b0010;  // bit 7
        4'b0010: if(BaudTick) state <= 4'b0011;  // stop1
        4'b0011: if(BaudTick) state <= 4'b0000;  // stop2
        default: if(BaudTick) state <= 4'b0000;
endcase
// Output mux
reg muxbit;
always @( * )
case(state[2:0])
        3'd0: muxbit <= TxD_dataD[0];
        3'd1: muxbit <= TxD_dataD[1];
        3'd2: muxbit <= TxD_dataD[2];
        3'd3: muxbit <= TxD_dataD[3];
        3'd4: muxbit <= TxD_dataD[4];
        3'd5: muxbit <= TxD_dataD[5];
        3'd6: muxbit <= TxD_dataD[6];
        3'd7: muxbit <= TxD_dataD[7];
endcase
// Put together the start, data and stop bits
reg TxD;
always @(posedge clk) TxD <= (state<4) | (state[3] & muxbit);  // register the output to make it glitch free
其中的
是什么意思?它能实现发送起始位0和两位停止位吗?
发表于 2010-5-24 11:21:38 | 只看该作者
在state<4时候,刚好是发送stop1 stop2所处状态,既然其条件为真,则发送的为高电平;当state[3]==1时候,刚好发送八位数据,而数据内容muxbit,故发送的就是八位数据,其实这个无非是把要发送的数据用clk时钟锁存后再送到TxD,以期去除毛刺。
 楼主| 发表于 2010-5-25 15:37:33 | 只看该作者
多谢
发表于 2010-8-11 09:27:45 | 只看该作者
回复 2# hdhuang
// Baud generator
`ifdef DEBUG
`else
`endif
里面的波特率是怎么产生的啊,请教一下。
发表于 2010-8-12 11:09:56 | 只看该作者
回复 1# zlsopc
这个模块我有点看不懂啊,可以不可以加点注释啊。谢了。
GMT+8, 2026-11-2 08:12 , Processed in 0.038843 second(s), 14 queries .
