查看: 9291|回复: 2
SCMA码本设计
发表于 2015-5-27 08:55:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
论文中“SCMA Codebook Design”中星座图旋转是对母星座图旋转还是对对形成母星座图的QPSK星座图旋转啊?
发表于 2015-5-27 15:16:46 | 只看该作者
你好,首先感谢提问。SCMA中的星座图旋转目的是防止用户在非正交扩频叠加的时候,造成解码的不唯一性。因此星座图旋转你可以理解为,先确定某一用户的星座,而其他用户基于此,然后通过旋转不同角度而得到。
发表于 2016-2-16 21:17:33 | 只看该作者
hi
Can you please help me how to design scma codebooks from mother constellation? I am implementing the *scma codebook design* paper. I have implemented untill the two projections of mother constellation(two 4x4 matrices). Now how can I get the codebooks (4x4).  The binary mapping matrix is 4x2 so i need a 2x4 matrix from the mother constellation..Please help me . how should I do this ? how to use the layer specific operator like phase rotation to get the codebook...
Thanks and Regards
Mehmoodd.alam@gmail.com
GMT+8, 2026-9-21 12:12 , Processed in 0.054242 second(s), 14 queries .
