查看: 6480|回复: 0
新手,求解一段verilog代码
发表于 2012-9-18 13:58:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//按键记数,数码管动态显示,两位
module test(clk,key,dispcode,CS);
input clk,key;
output reg [6:0] dispcode = N0;
output reg [1:0]CS;
reg [6:0]num;
reg [3:0]num_t;
reg [19:0]count1;
reg [7:0]count2;
reg timeflag;
reg keyflag = 1,lastkeyflag=1; // 1 up ,0 down
/*        共阴极 :不带小数点
0,  1,  2,  3,  4,  5,  6,  7,
3fh,06h,5bh,4fh,66h,6dh,7dh,07h
8,  9,
7fh,6fh,00h*/
parameter  N0  = 7'h3f,
                  N1  = 7'h06,
                  N2  = 7'h5b,
                  N3  = 7'h4f,
                  N4  = 7'h66,
                  N5  = 7'h6d,
                  N6  = 7'h7d,
                  N7  = 7'h07,
                  N8  = 7'h7f,
                  N9  = 7'h6f,
                  N10 = 7'h77;
always @(posedge clk)
                if(count1 < 20'd500000)  //10ms
                        count1 = count1+1'd1;
                                count1=0;
                                if(count2 < 1) //
                                        count2=count2+1'd1;
                                                count2=0;
                                                timeflag = ~timeflag; //每10ms翻转一次
always @(posedge timeflag)  //延时去抖动
                if(lastkeyflag==0 && key == 0)
                        keyflag = 0;
                if(lastkeyflag==1 && key == 1)
                        keyflag = 1;
                lastkeyflag = key;
always @(negedge keyflag)
                num <= num + 1'd1; //
                if(num>99)
                        num <= 0;
always @(posedge timeflag)        //数码管动态显示 这里为什么不能改成 always @(timeflag)
                CS = CS + 1;
                if(CS > 2'd2)
                        CS = 2'd1;
                if(CS==2'd1)
                        num_t = num%10;
                if(CS==2'd2)
                        num_t = num/10;
                case(num_t)
                        4'd0 : dispcode = N0;
                        4'd1 : dispcode = N1;
                        4'd2 : dispcode = N2;
                        4'd3 : dispcode = N3;
                        4'd4 : dispcode = N4;
                        4'd5 : dispcode = N5;
                        4'd6 : dispcode = N6;
                        4'd7 : dispcode = N7;
                        4'd8 : dispcode = N8;
                        4'd9 : dispcode = N9;
                        4'd10: dispcode = N10;
                default: dispcode = 7'h40;
                endcase
问题:
这条语句如果改成 always @(timeflag)   就不对了,timeflag我设置的是10ms翻转一次,改完之后应该动态扫描的频率更快了才对啊?
哪位大神指导一下,谢谢!
GMT+8, 2026-11-3 12:20 , Processed in 0.036466 second(s), 14 queries .
