查看: 6502|回复: 1
时序式设计出来的实例 : (decoder 端)
发表于 2010-4-6 23:55:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
接收端的架构必须根据传输端的规划把传输的数据再解回来
(这边同样须规划 timing diagram => coding => simulation 看是不是符合所想要的时序)
ps : 真正在两个 device 间的传输, 不可以跑这么快的频率, 需要注意一下, 这边是简单的举个很实用的例子分享喔~ :$
module ext_pll_slave
    // system input
    osc_50,
    rstn,
    // 2-wire interface
    max_sclk,
    max_sdat,
    // device 1 output
    clk1_pr,
    clk1_od,
    clk1_os,
    clk1_ce,
    clk1_rstn,
    // device 2 output
    clk2_pr,
    clk2_od,
    clk2_os,
    clk2_ce,
    clk2_rstn,
    // device 3 output
    clk3_pr,
    clk3_od,
    clk3_os,
    clk3_ce,
    clk3_rstn
//  Port declarations
// system input
input           osc_50;
input           rstn;
// 2-wire interface
input           max_sclk;
inout           max_sdat;
// device 1 output
output    [1:0] clk1_pr;
output    [2:0] clk1_od;
output    [1:0] clk1_os;
output          clk1_ce;
output          clk1_rstn;
// device 2 output
output    [1:0] clk2_pr;
output    [2:0] clk2_od;
output    [1:0] clk2_os;
output          clk2_ce;
output          clk2_rstn;
// device 3 output
output    [1:0] clk3_pr;
output    [2:0] clk3_od;
output    [1:0] clk3_os;
output          clk3_ce;
output          clk3_rstn;
//  Parameter declarations
//  Signal declarations
reg      [3:0] clk3_set;
reg      [3:0] clk2_set;
reg      [3:0] clk1_set;
wire    [11:0] conf_data;
reg            conf_duration;
reg            conf_duration_d;
reg            max_sdat_d;
reg      [4:0] conf_counter;
wire           duration_end;
wire           conf_counter_zero;
reg            conf_wr;
reg     [11:0] s2p;
wire           wr_data_ready_temp;
reg            wr_data_ready;
reg            p2s;
reg            p2s_act;
//  Structural coding
assign max_sdat = p2s_act ? p2s : 1'bz;
assign conf_data = {clk3_set, clk2_set, clk1_set};
assign duration_end = (conf_counter == 5'd16) ? 1'b1 : 1'b0;
assign conf_counter_one = (conf_counter == 5'd1) ? 1'b1 : 1'b0;
assign wr_data_ready_temp = (conf_counter == 5'd14) ? 1'b1 : 1'b0;
//--- pipe delay ---//
always @ (posedge osc_50 or negedge rstn)
        if (!rstn)
                max_sdat_d <= 1'b1;
                max_sdat_d <= max_sdat;
//--- config duration ---//
        if (!rstn)
                conf_duration <= 1'b0;
  else if (duration_end)
        else if (max_sdat_d && !max_sdat)
                conf_duration <= 1'b1;
//--- config counter---//
        if (!rstn)
                conf_counter <= 5'b0;
        else if (!conf_duration)
                conf_counter <= conf_counter + 1;
//--- s2p convert ---//
always @ (posedge max_sclk)
        if (conf_duration)
                if (conf_counter_one)
                        conf_wr <= max_sdat;
                if (conf_wr)
            s2p <= {s2p[10:0], max_sdat};
        if(!rstn)
                wr_data_ready <= 1'b0;
        else if (conf_wr && wr_data_ready_temp)
                wr_data_ready <= 1'b1;
//--- p2s convert ---//
  if (!rstn)
          p2s <= 1'b1; p2s_act <= 1'b0;
  else if (!conf_wr)
    case (conf_counter)
            5'd2    : begin p2s <= conf_data[11]; p2s_act <= 1'b1; end
            5'd3    : p2s <= conf_data[10];
            5'd4    : p2s <= conf_data[9];
            5'd5    : p2s <= conf_data[8];
            5'd6    : p2s <= conf_data[7];
            5'd7    : p2s <= conf_data[6];
            5'd8    : p2s <= conf_data[5];
            5'd9    : p2s <= conf_data[4];
            5'd10   : p2s <= conf_data[3];
            5'd11   : p2s <= conf_data[2];
            5'd12   : p2s <= conf_data[1];
            5'd13   : p2s <= conf_data[0];
      default : begin p2s <= 1'b1; p2s_act <= 1'b0; end
    endcase
          p2s_act <= 1'b0;
//--- programming data latched ---//
        if (!rstn)
    clk3_set <= 4'h4; //only for test
    clk2_set <= 4'ha; //only for test
    clk1_set <= 4'hc; //only for test
  else if (wr_data_ready)
    clk3_set <= s2p[11:8];
    clk2_set <= s2p[7:4];
    clk1_set <= s2p[3:0];
发表于 2011-7-22 18:49:07 | 只看该作者
wow,好厉害!!学习大大!!
GMT+8, 2026-11-2 04:11 , Processed in 0.031711 second(s), 14 queries .
