查看: 4728|回复: 0
求助,DE2和ADA_GPIO子卡的问题
发表于 2011-5-3 14:17:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我现在想用函数信号发生器给ADA_GPIO子卡的AD_A通道输入一个正弦信号,然后不通过任何处理,再从ADA_GPIO子卡的DA_A通道输出,理论上来讲,DA_A通道应该能从示波器上看到正弦信号,但是,我看不到信号。现在,我把我的程序贴上,请高手指点一下。
module ada   (
                        CLOCK_50,
                        ADC_CLK_A,
             ADC_CLK_B,
        ADC_DA,
        ADC_DB,
        ADC_OEB_A,
        ADC_OEB_B,
        ADC_OTR_A,
        ADC_OTR_B,
        DAC_CLK_A,
        DAC_CLK_B,
        DAC_DA,
        DAC_DB,
        DAC_MODE,
        DAC_WRT_A,
        DAC_WRT_B,
        OSC_SMA_ADC4,
        POWER_ON,
               SMA_DAC4
input                                          CLOCK_50;
output                                  ADC_CLK_A;
output                                  ADC_CLK_B;
input                    [13:0]                ADC_DA;
input                    [13:0]                ADC_DB;
output                                  ADC_OEB_A;
output                                  ADC_OEB_B;
input                                          ADC_OTR_A;
input                                          ADC_OTR_B;
output                                  DAC_CLK_A;
output                                  DAC_CLK_B;
output                 [13:0]                DAC_DA;
output                 [13:0]                DAC_DB;
output                                  DAC_MODE;
output                                  DAC_WRT_A;
output                                  DAC_WRT_B;
output                                        POWER_ON;
output                  OSC_SMA_ADC4;
output                  SMA_DAC4;
assign  DAC_WRT_B = CLOCK_50;      //Input write signal for PORT B
assign  DAC_WRT_A = CLOCK_50;      //Input write signal for PORT A
assign  DAC_MODE = 1;   //Mode Select. 1 = dual port, 0 = interleaved.
assign  DAC_CLK_B = CLOCK_50;             //PLL Clock to DAC_B
assign  DAC_CLK_A = CLOCK_50;             //PLL Clock to DAC_A
assign  ADC_CLK_B = CLOCK_50;              //PLL Clock to ADC_B
assign  ADC_CLK_A = CLOCK_50;              //PLL Clock to ADC_A
assign  ADC_OEB_A = 0;                               //ADC_OEA
assign  ADC_OEB_B = 0;                             //ADC_OEB
assign  POWER_ON  = 1;
assign  DAC_DA = ADC_DA;
GMT+8, 2026-11-24 12:41 , Processed in 0.031682 second(s), 16 queries .
